Activity Forums Apple Final Cut Pro Legacy Master quicktime sources
  • Master quicktime sources
    Posted by Lili Chin on June 4, 2008 at 6:19 pm
    Hello,
    I am looking to playback master quicktime files in HD format. So far, I have been working with final cut pro to generate these files, importing from various different HD formats to create a DVCPRO HD master. There are 2 questions I have with this:
    1. Is DVCPRO HD the best format I should master to (in HD) *I can’t playback an HD 10 bit uncompressed 4:2:2 without a Raid from my understanding. If not DVCPRO HD, should I use Pro Res 4:2:2
    2. When I export using quicktime conversion, it only lets me go to MED, why is this so?
    What can I do to change this?
    best
    lili
    Russell Lasson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Russell Lasson
    June 4, 2008 at 6:48 pm
    [Lili Chin] “1. Is DVCPRO HD the best format I should master to (in HD) *I can’t playback an HD 10 bit uncompressed 4:2:2 without a Raid from my understanding. If not DVCPRO HD, should I use Pro Res 4:2:2 “
    I would suggest editing and mastering in ProRes.
    [Lili Chin] “2. When I export using quicktime conversion, it only lets me go to MED, why is this so?
    What can I do to change this? “
    If you’re exporting as the codec that you edited in, I would suggest using Export-QuickTime Movie instead of QuickTime conversion.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
