Activity Forums Adobe Premiere Pro Master Export best DNxHD OPIa settings Premiere cc 2015 PC
  • Master Export best DNxHD OPIa settings Premiere cc 2015 PC
    Posted by Cammie Noel on July 29, 2019 at 7:54 pm
    I need the best export settings for the highest quality master export in Premiere cc 2015 on a PC
    DNxHD OPIa is the format in my sequence settings.I want to export a master in DNxHD OPIa
    Have had issue with computer shutting OFF during trying to export this high quality version DNxHD OPIa but when i exported h264 it was fine.I want the BEST quality master i can get on this machine. Am exporting to internal drive that has 1 TB of space available. C drive has 462 GB of space on it. Graphics card is GE Force GTV 660
    I have rendered the sequence and cleaned media cache. The original footage was shot on a Sony PXW-x 70 and a few clips were shot on an iphone ,then all converted to Pro Res 4444 on a mac, before edited in Premiere in DNxHD OPIa
    format . Size is 1920×1080
    Its a bit confusing to me on exactly which settings in the drop down menu to select for export .
    Thank you for any info on this.
    Cammie Noel replied 7 years, 1 month ago 2 Members · 6 Replies
  • Shane Ross
    July 29, 2019 at 10:02 pm
    Try DNxHD Quicktime. OP1A is a very specific format that I haven’t had the luck getting out of Premiere yet. Only able to do it in Resolve and Avid. But a DNxHD QT file will be pretty high quality. If you export 175x or 220x, it’ll even be 10-bit. Whereas most of the DNxHD formats are 8-bit, and OP1A is 8 bit…it’s an XDCAM 50 format.
    DNxHD 220x is much akin to ProRes HQ.
    Shane
    Little Frog Post
  • Cammie Noel
    July 29, 2019 at 11:49 pm
    Thanks very much, sounds great but I don’t see that as an option in the drop down menu .
  • Shane Ross
    July 30, 2019 at 12:09 am
    Well, I think Adobe calls it simply “DNxHD 145/175/220” And then there should be a place to get specific. Let me look on my system when I get home.
    Shane
    Little Frog Post
  • Cammie Noel
    July 30, 2019 at 12:32 am
    Cool…OK thanks. Much appreciated
  • Shane Ross
    July 30, 2019 at 4:59 am
    OK…here goes. I did NOT see DNxHD/DNxHR listed in my options for Quicktime. Even though I have the Avid codecs installed. Stupid. BUT…if I choose Cineform, then go to the VIDEO TAB below, and under VIDEO CODEC, change it to DNXHD/HR….and then choose the RESOLUTION DNxHD HQX 10-bit…I got it.
    Shane
    Little Frog Post
  • Cammie Noel
    July 30, 2019 at 6:20 pm
    Thanks Shane I’ll give that a go.
