Activity › Forums › Adobe Premiere Pro › Master clip stops playing after (3-5) minutes but timeline continues
  • Master clip stops playing after (3-5) minutes but timeline continues
    Posted by Eclip5e on November 4, 2005 at 3:15 pm
    I’ve dropped 2 master clip source videos onto 2 video tracks, but they stop playing after about 3-5 minutes into the clip. The video frame freezes, and the audio stops. The timeline keeps going like its playing normally.
    The clip is a raw avi from a miniDV camera, uncompressed NTSC video.
    any ideas?
    Eclip5e replied 20 years, 11 months ago 3 Members · 4 Replies
  • Rj Hewitt
    November 4, 2005 at 6:47 pm
    Does the same happen when putting the clips end to end on the same video track?
    What spec is your setup? (CPU, Ram, Drives, Premier version and OS etc.)
  • Eclip5e
    November 4, 2005 at 6:55 pm
    It happens if i do end-to-end, different tracks, different sequence. I capture the video using Microsoft Movie Maker since Premiere doesn’t like to properly detect my Panasonic GS120 camera. It also happens with other cameras as well, so thats not the problem. It also happens with other sources of video as well, not just stuff from cameras.
    1.8Ghz AMD
    1gb ram
    80gb hard drive western digital 7200rpm with 8mb cache
    Win XP Sp2
  • Mike Velte
    November 4, 2005 at 7:19 pm
    Premiere cannot handle the DV codec Movie Maker exports (DirectShow type 1). Try capturing with ScenalyzerLive…it is the cats meow! scenalyzer.com
  • Eclip5e
    November 4, 2005 at 7:41 pm
    Its works, but it just stops after a while. Are you saying it doesn’t work at all? Because i can view it.
