Activity Forums VEGAS Pro Master Bus Fader Locks up Vegas
  • Master Bus Fader Locks up Vegas
    Posted by Roger Woolnough on October 10, 2014 at 7:31 am
    In Vegas Pro 13 (build 373), I can move the master bus fader OK if no files or projects are open. But if anything is open, even just one audio file, when I try to move the fader, it may move slightly, then freezes. After that, I cannot make anything work; no menus or track controls, etc. The only exception I have found is that the project will play using the spacebar to start and stop. Then, I need to force-close Vegas using Windows Task Manager.
    If instead of using the fader beside the level meter, I open the mixer window, and move the master bus fader in the mixer window, no problem. Then, when I close the mixer window, the fader attenuation in the main window correctly shows the change I made. So, this is a workaround for me, but I can’t make it move directly.
    Is this a bug, or am I missing something here?
    Steve Rhoden replied 11 years, 11 months ago 3 Members · 3 Replies
  • Steve Rhoden
    October 10, 2014 at 3:51 pm
    No, you are not missing anything Roger. It is a bug, but im not sure if
    it will be addressed in the next update!
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Nigel O’neill
    October 11, 2014 at 1:04 am
    Roger/Steve, a workaround:
    https://forums.creativecow.net/readpost/24/982596
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Steve Rhoden
    October 11, 2014 at 10:48 am
    I know about the workaround Nigel. Hoping its addressed along with
    others in an update.
