Activity Forums Apple Final Cut Pro Legacy MASSIVE playback issues
  • Aaron Zander
    October 11, 2007 at 1:59 pm
    [walter biscardi] “What you want to do is retain the frame size, but make the file sizes smaller so FCP can work with them.
    We are talking thousands and thousands of images. This is all high speed photography rangin from 100-500 fps. the shortest clip is only 400 frames, but the longest is nearly 3000.
    ontop of this, wouldn’t going to pro res have handled this?
  • Daniel Miller
    October 11, 2007 at 2:15 pm
    Earlier you mentioned this is high speed photography. Are you putting the tiffs in order in your timeline to make it play as a clip? I guess that post through me off a bit. If this is the case, you can use quicktime to build the clips from the images for you. If they are numbered sequentially, open up quicktime file>import>images sequence I believe, and it will ask you for the first image in the sequence. Point it to the first image and then it will build the clip for you. Export it from QT into whatever format you want. If im totally wrong about what youre trying to do, I apologize. Anyway, I hope this helps in some way.
  • Aaron Zander
    October 11, 2007 at 2:21 pm
    sorry missed this, dang cow forums hiding posts from me.
    They were quicktimes already. the tiff files them sleves have never actually touched this timeline. I made image sequences out of them via QT and moved on to pro res. and still had my issues
  • Aaron Zander
    October 11, 2007 at 3:00 pm
    I would like to report this problem as SOLVED!!!!!
    final cut, has apparantly out witted me not once but about fifteen times x 20 clips. so, I’m retiring my computer, and would like to state “DUDE IM GETTING A DELL” ok, well maybe not
    heres what happned. Every time I reconnected to other lower res formats, such as the pro res or the h.264’s it didn’t actually do it. It said it did it, It told me it did it. But I’ve now moved those quicks times deep into the bowels of fake file structure hell and fcp cant find them HAHAHA i have beaten the beast. It is now playing my pro res files and running happy.
    Thanks for the help
    -Aaron
  • Walter Biscardi
    October 11, 2007 at 3:09 pm
    [A.Zander] “ontop of this, wouldn’t going to pro res have handled this?”
    No, that’s only a different codec, doesn’t do anything with the original file size.
    [A.Zander] “We are talking thousands and thousands of images. This is all high speed photography rangin from 100-500 fps. the shortest clip is only 400 frames, but the longest is nearly 3000.”
    Then you set up an automated function in Photoshop to handle that.
    The file size is the most likely reason for the playback issues. If you don’t want to re-adjust everything down to 72dpi, then you will most likely continue to have playback issues.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • David Bogie
    October 11, 2007 at 4:27 pm
    AZ:
    Thank you very much for having the courtesy to come back and close your post with a solution. Hardly anyone ever does that around here.
    bogiesan
  • Aaron Zander
    October 11, 2007 at 4:33 pm
    Your very welcome, Heres the cut so far by the way (rough) with no graphics yet
    https://download.yousendit.com/2173454570F088CC, yes that noise is actually on the image, Thanks bad DIT for telling us the image on the monitor was a lo res version and it would look perfectly clear. Don’t you love that?
  • David Roth weiss
    October 11, 2007 at 4:40 pm
    The link isn’t working for some reason… Since I didn’t sleep because of this I want to see… Please post a good link.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Aaron Zander
    October 11, 2007 at 4:45 pm
  • David Roth weiss
    October 11, 2007 at 6:00 pm
    I like it!!! The different rates and movements and styles within the overall style make it more are interesting too.
    David Roth Weiss
    Director/Editor
    Los Angeles
Page 2 of 3
