Activity Forums Apple Final Cut Pro Massive FCPX Project
  • Massive FCPX Project
    Posted by Joshua Moise on September 5, 2014 at 12:57 pm
    Hi there,
    I’m wrapping up a feature film I cut on FCPX and the project has become completely unwieldy at 533 GB. It’s so gigantic that occasionally it takes twenty minutes to load.
    How do I make FCPX projects smaller? I’ve already deleted unused render files and it only took off a relatively small amount of data.
    Josh
    Craig Alan replied 11 years, 11 months ago 6 Members · 10 Replies
  • 10 Replies
  • Nikolas Bäurle
    September 5, 2014 at 2:06 pm
    You could consolidate the project:
    https://support.apple.com/kb/PH12706
    “Always look on the bright side of life” – Monty Python
  • Jeremy Garchow
    September 5, 2014 at 2:16 pm
    What version of X?
  • James Ewart
    September 5, 2014 at 2:44 pm
    And which Mac are you using please?
  • Joshua Moise
    September 5, 2014 at 3:01 pm
    Using the newest version of FCPX. OSX 10.9.4
  • Jeremy Garchow
    September 5, 2014 at 3:14 pm
    Are you using Proxy media? Where’s your cache stored? Where your optimized media stored.
    A few more details about how set up the Library might help.
    Where is your Library located (what kind of drive)?
  • Joshua Moise
    September 5, 2014 at 3:19 pm
    All the media is on one hard drive. I did not use optimized media, so I think it’s referencing proxy files or the raw media itself. All the other files are located within the library file that’s so huge. It’s on a Glyph Thunderbolt drive.
    J
  • Noah Kadner
    September 5, 2014 at 3:46 pm
    Yeah I’d back it up and then Consolidate it.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Jeremy Garchow
    September 5, 2014 at 4:15 pm
    [Joshua Moise] “All the media is on one hard drive. I did not use optimized media, so I think it’s referencing proxy files or the raw media itself. All the other files are located within the library file that’s so huge. It’s on a Glyph Thunderbolt drive.”
    Single click the Library and open the inspector (command-4).
    In there, you should see where the media is located, and how much space it is taking up on your drive.
    It should look something like this:
  • Craig Alan
    September 6, 2014 at 5:02 am
    500 gb is not massive. Get a thunderbolt raid. Check out owc if u can’t afford a Pegasus. A single drive is not going to cut a feature w comfort. And max out your ram. Make sure to leave a lot of headroom on your media drive. Past 75% or so will slow things down.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • Craig Alan
    September 6, 2014 at 5:04 am
    What codec is it in? You might need to optimize.
