Activity › Forums › Adobe Premiere Pro › Mass ripple delete? PPRO 2
  • Mass ripple delete? PPRO 2
    Posted by Nathan Quattrini on June 15, 2007 at 3:39 pm
    I`m curious if there is a way to ripple delete all spaces between clips at once. Lets say you have a 5 minute clip, you delete every other 20 seconds…now your clip has a whole lot of holes….do you have to ripple delete every gap one by one? or is there a way to pull all the clips together at once?
    Steven L. gotz replied 19 years, 3 months ago 2 Members · 1 Reply
  • Steven L. gotz
    June 16, 2007 at 9:21 pm
    No, there is no way to do that. But you might want to reconsider your work flow.
    If you select portions of your clips in the Source monitor, then put them on the sequence, you won’t have that problem.
    Steven
    https://www.stevengotz.com
