Activity › Forums › Adobe After Effects › Mass Replace
  • Mass Replace
    Posted by Alan Balch on December 15, 2014 at 3:50 pm
    I’ve got a comp with multiple layers on it and I’ve received a request to replace the current graphics with new ones that behave the same way.
    I know that I can use OPTION+ CLICK to replace one element in a project with another one in a comp. Can I replace multiple items in a composition this way? I’d rather do it this way than having to restart the project.
    Alan Balch
    Videographer/Carle Foundation Hosptial
    alan.balch@carle.com
    Daniel Waldron replied 11 years, 9 months ago 3 Members · 3 Replies
  • Walter Soyka
    December 15, 2014 at 4:01 pm
    You can use Option+drag to replace a selection of layers in a comp with a single layer from the project panel. If you have multiple source items you need to uniquely replace, you can do them one at a time, but it goes very quickly.
    You can right-click any footage element in the project panel and choose “Replace with Precomp” to replace all instances of its use with a precomp. Then, by editing the precomp, you affect all uses.
    You can Option+drag one item in the project panel onto another to replace every instance of its use.
    You can right-click any item in a project panel and replace the footage it refers to.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Alan Balch
    December 16, 2014 at 3:02 pm
    Walter,
    Thanks again for your help, pardoner. I ended up just replacing each layer with an OPT+DRAG. It didn’t take long at all.
    I need to work on my animation skills and any help I can get is appreciated. I tried to animate falling snowflakes at the end of the piece and I feel that they look more like ninja stars and falling rocks than snowflakes.
    Tell me what you think. https://vimeo.com/114668792
    Thanks again!
    Alan Balch
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Daniel Waldron
    December 16, 2014 at 6:27 pm
    The snowflakes aren’t bad at all. A few thoughts on how to improve the animation a little:
    – Instead of fading them in and then starting the animation, just start the animation above your composition so they fall down into the screen.
    – Some of flakes seem to change direction suddenly. Make the change in direction a little smoother and less drastic. Perhaps look into wiggle expressions to add some random movement to them.
    – Don’t ease the animation out at the end. Snowflakes don’t know where the ground is, so why would they slow down for it? 😉 Also, make sure the rotation of the flakes ends when the reach the ground.
    Hope that helps!
