Activity › Forums › Adobe Premiere Pro › Masks revealed in youtube
  • Masks revealed in youtube
    Posted by Panos Smirniotis on November 1, 2016 at 2:11 pm
    I had to make some quick product videos (had no special lighting setup, just used the modeling lights of my studio monolights and my WB was terrible for start) to compliment the catalogue photoshoot of the products I was doing at the same time.
    Working on Premiere pro I had to do some color correction and MASK OUT the sides of the white background showing in some cases. While in the output video the masks dont show when the videos uploaded in youtube the masks on some cases are showing and the result is terrible.
    https://www.youtube.com/watch?v=_UBjgeYgIk0 (WB is bad I know)
    Playing the original clip in my system doesnt show the masks (media player classic).
    I am guessing this is happening because of the re-encoding of youtube limiting the shades of “white” or something?
    Do you have any idea how can I correct this? Different export setting in PP maybe?
    clip info:
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.259
    Stream size : 6.11 MiB (97%)
    Language : English
    Encoded date : UTC 2016-09-23 08:11:18
    Tagged date : UTC 2016-09-23 08:11:18
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Panos Smirniotis replied 9 years, 11 months ago 1 Member · 1 Reply
  • Panos Smirniotis
    November 1, 2016 at 4:04 pm
    Thank you
    First time in years I didn’t bother do the real edit in AE, and this happens.
    I tried your approach in the first scene where the problem was so obvious and it worked great ( I needed to play with adjusting the mask path and mask feather vaule to make it seamless but as I stated it my op I dont want to bother much and more with this. It’s fine as it is. (oh this WB is killing me though)).
    https://www.youtube.com/watch?v=AmMKJSjkIOc&feature=youtu.be
    Thank you Dave, I really appreciate all your effort helping people here for so long and of course me in this case. Hope you are doing great.
