Activity Forums Adobe After Effects masks on pre-comps have no effect?
  • masks on pre-comps have no effect?
    Posted by Sean90291 on May 30, 2007 at 9:18 pm
    I have created a pre-comp which consists of two layers: one contains a mask, and the other contains an effect. I then took that pre-comp into another composition where I want to layer it over another layer, which requires that I mask the resulting pre-comp image. But when I draw a mask over the pre-comp it doesn’t do anything. That is, it remains a solid layer, and doesn’t “cut anything out” so that I can see the layer underneath. How do you mask out parts of a pre-comp?
    Kevin Camp replied 19 years, 3 months ago 3 Members · 5 Replies
  • Sean90291
    May 31, 2007 at 12:33 am
    Yup. The Mask is set to Add. I’ve tried subtract, difference and inverted too. Masks work on everything else. So I just think there’s gotta be something about pre-comps and masks I’m missing.
  • Sean90291
    May 31, 2007 at 12:36 am
    Okay, stop the presses. I wondered what would happen if I removed the TimeWarp effect, also applied to the pre-comp. Lo and behold, the mask now works. So apparently it’s the fact that you can’t apply masks to a Timewarped layer, not that I can’t apply masks to a pre-comp. I’ll have to see if I can mask it and THEN apply the Timewarp after.
  • Sean90291
    May 31, 2007 at 1:01 am
    Okay, then I really need to know how to mask a Timewarped layer/pre-comp. That turns out to be the real issue. As soon as I add Timewarp, the mask ceases to reveal the layer beneath. Sigh.
  • Darby Edelen
    May 31, 2007 at 1:35 am
    How about masking the pre-comp, then pre-comping it and applying the Timewarp? (; Not the most elegant solution but I can’t think of any reason why it shouldn’t work.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Kevin Camp
    May 31, 2007 at 2:17 pm
    or apply timewarp as an adjustment layer in the on comp, then use the mask as you were in the other comp.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
