Activity Forums Adobe After Effects Masks not updating on screen when edited
  • Masks not updating on screen when edited
    Posted by Matt Pettit on April 9, 2019 at 1:19 pm
    For quite a long time now, over a few versions of AE, sometimes when I edit a mask path keyframe it doesn’t update on screen (change).
    If I change the resolution to half, it will then update but if I go back to full, even after rendering it, it goes back to how it was.
    This is obviously a big part of my job as a VFX Artist so wondered if this is a known issue that can be easily fixed?
    Austin Hill replied 6 years, 11 months ago 3 Members · 3 Replies
  • Tomas Bumbulevičius
    April 10, 2019 at 4:55 pm
    Matt, that sounds pretty strange. Any chance you have some effects/transformations applied to the layers itself? Based on this, it might be possible to spot a pattern.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
  • Austin Hill
    October 16, 2019 at 2:13 am
    No, this is 100% a bug.
    It happens to me as well. I’ll clear the cache and then suddenly the mask will jump into the proper space.
    I thought Adobe fixed this an update ago…
    NOPE
    I’m on:
    16.1.3
  • Austin Hill
    October 16, 2019 at 2:25 am
    Still a bug, but I found a “solution” by hiding the mocha AE CC filter. For whatever reason the masks would suddenly be responsive. It shouldn’t make a difference because the filter wasn’t even really doing anything.
