Activity Forums Adobe After Effects masks and transparency for output
  • masks and transparency for output
    Posted by Christina Ricci on January 10, 2011 at 10:05 pm
    I have created multiple masks (4 layers) to reveal elements of one layer. I need to export with alpha channel and when I turned on the transparent background, ready for rendering, I noticed my masks were black. What do I need to do to make the masks output correctly?
    Thanks for help!
    Christina
    Christina Ricci replied 15 years, 5 months ago 36,847 Members · 1 Reply
  • Christina Ricci
    January 10, 2011 at 11:20 pm
    Hi Dave,
    Actually ended up doing Keylight in FCP with one pass and lots of fine tuning, and with no masks. Adding a mask to inside well was crashing FCP continually or creating a grey silo. I believe the primary issue: if I had pure HD and not HDV my keying would have been easier and ultimately cleaner. My final is good though for what I will use it for.
    I just figured out the alpha. I am referring to creating multiple masks using solid layers so I can target just one layer. My masks were showing black so I finally figured out its changing mode to Silhouette Alpha.
    Thanks! Much appreciated!
    Christina
