Activity Forums Adobe After Effects Mask/Path Snapping Problem in CC 2015
  • Mask/Path Snapping Problem in CC 2015
    Posted by Chris Lones on October 23, 2015 at 4:38 pm
    Greetings,
    I’ve run into some wonky results recently when trying to manipulate groups of vertices or entire masks/paths.
    For instance…Currently, I would like rotate my shape’s path 180 degrees. Like normal, I select all the points, double-click to get the transform box around them, hold shift for snapping, and then rotate it until it snaps into the spot I want. Should be pretty simple, right?
    Instead, it rotates 45 degress, then 90 as it should, but as I continue to drag towards 180, the whole transform box will suddenly begin sliding its position instead of continuing to rotate. Or suddenly start re-sizing instead of rotating. It’s frustrating to no end.
    I get similar results when trying to re-size from the anchor point using CTRL. It starts to re-size like normal, then spontaneously slides in the direction of my mouse drag instead. In both situations, I will try multiple times, and the bug happens at random points during my rotation/re-size. It doesn’t seem to be triggered by crossing a certain point in the transform.
    Finally, I don’t believe this was a problem when I first jumped from CC 2014 to 2015. I *think* it may have begun after one of the last few updates, but I’m not totally sure. I know the most recent update didn’t fix it.
    Has anyone run into similar behavior and/or discovered a solution? I’m currently working around it by doing everything manually, which is fine, but I feel like I’ve lost significant speed and precision.
    Any help would be very much appreciated. Thanks!
    Chris Lones
    Danny Jenkins replied 9 years, 1 month ago 3 Members · 2 Replies
  • Jeff Bobbington
    January 4, 2016 at 2:13 pm
    This has started happening to me after upgrading from CS6 to CC2015.
    It’s like it forgets you are holding down the shift key.
    I have no solution.
    Strange that its not a more reported issue as its a function I use very often.
  • Danny Jenkins
    August 21, 2017 at 4:45 am
    Found this thread while searching for a solution to this – still happening to me on CC2017
    Only happens on Windows OS for me, mac is fine.
    Best regards,
    Danny Jenkins
