Activity › Forums › Adobe Premiere Pro › Masking unwanted object
  • Masking unwanted object
    Posted by Niya Be on July 7, 2020 at 5:34 pm
    Hello
    I’m a premiere pro beginner…
    I have a clip with a static object that I want to hide. It’s in the corner of the floor and the wall of the space. I have another clip with that area without the object. Can I do something similar to Photoshop where I would copy the area around the object from one clip and paste in to the other to cover the unwanted object with the ’empty’ space? Sorry if it is a dumb question!
    Niya Be replied 6 years, 2 months ago 2 Members · 3 Replies
  • Todd Perchert
    July 7, 2020 at 6:45 pm
    Yes. You can mask out the area. Place your video without the object on layer 1. Place your video with the object on layer 2. Select layer 2. In your Effect Controls panel, you will find a pen tool below the Opacity. Draw your area you want to cut out. Feather options to suit.
    Good Luck!
    TC
  • Todd Perchert
    July 7, 2020 at 6:46 pm
    I should mention, you may need to Invert it as well. 🙂
  • Niya Be
    July 9, 2020 at 4:51 pm
    Thank you! It works:)
