Activity Forums VEGAS Pro Masking question
  • Masking question
    Posted by Jon Smith on January 17, 2009 at 1:26 am
    I am playing around, watching light saber effect tutorials and I can get the mask started, but when I go to keyframe and move the four points that do the masking, it moves around all over the place (doesn’t keep it’s rectangular shape) and does some really strange things once I continue to use the anchor creation tool. Any advice?
    Joe Mantaratz replied 17 years, 8 months ago 3 Members · 2 Replies
  • Steve Rhoden
    January 17, 2009 at 4:01 am
    Just drag the mouse over the entire points to
    have them all selected …after all the points are
    highlighted you can then drag/move the entire mask
    seamlessly (keeping it’s rectangular shape).
    Hope that helps…sometimes for new users it can get
    a little tricky to master.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Joe Mantaratz
    January 17, 2009 at 4:12 am
    What is happening is you are getting the bezier curve and that can be confusing to deal with. After you are done with your mask you need to go frame by frame and adjust your mask points as needed to make it as neat as possible. This is very time consuming and when you do the math you will see why. You’ll sometimes want to only select one anchor or maybe the whole mask. You can do either by right clicking on the mask and then selecting the “ENTIRE MASK” or just an “ANCHOR”. Once you have selected either you can use your arrow keys to move them easily. You’ll have to do this anytime there is movement or change in shape. Select feather for both in and out in the properties as well to help give a more blended look. Play with the settings to get the look you want.
    Now for the math…30 Frames per second=1800 per minute. Times that by the total time and you can quickly see how long it can take. Now of course if there is not much movement it will be much less but either way if you want it to really come out well you have to spend the time. Or buy some extra software to help..
    Joe
