Masking query
Posted by David Hague on December 29, 2017 at 6:10 amIn Photoshop, if you have two images – one on top of the other – and you want to blend between the two so they appear side by side like below, it is relatively easy. But doing it in Vegas with video has me flummoxed! Any clues please? Many thank you’s ☺
John Bolton replied 8 years, 8 months ago 2 Members · 6 Replies -
John Bolton
December 29, 2017 at 8:31 amPlace the two pieces of media one above the other on the timeline ///
You use the Event/Pan Crop selection and select the Mask Tick box at the bottom left. Then draw around the section you want to see and then select Feather Out or In to soften the centre edges. Do the same for the other timeline media. You can re-position the media using Track Motion.. Hope this helps -
John Bolton
January 1, 2018 at 3:59 pmDid you solve the problem?.. I can send you a configured Veg if you need it..
David Hague
January 2, 2018 at 2:46 amIt did; thank you so much! But I would appreciate a VEG too if it is not too much trouble?
David
David
John Bolton
January 2, 2018 at 8:38 amHello David
Just a quick bit of merging. Nothing special but just in case you need to see.
https://www.dropbox.com/s/bj25q47o842x7vf/merge.zip?dl=0Thanks for letting us know you solved your query. it is always nice to get feedback as other users may not know whether the solutions work or not..
Regards
