Activity Forums Adobe After Effects Masking problems in AE
  • Masking problems in AE
    Posted by Bur Ci on July 12, 2014 at 2:36 am
    Howdy all,
    Perhaps I just really am having a hrad time understading basic AE tricks or something is wrong with my software but I am having a real hard time with a mask that I want to do and just really annoyed at this point trying to solve it.
    Well as you see, I have a TV and I want to superimpose channel noise on it by using a mask. I’ve put the noise video clip above my TV file and started to use the pen on the TV file. Here is where I run into issues.
    1. When I try to use the pen tool, I try to add points but I’m use to adding points in Illustartor a ceratin way. When I try to add points in After Effects, I can only creat point one and two and nothing beyond that. If I try to add a point it will be created on the a line i’ve created.
    2. I am not sure how but I did create a third point and able to close the path/mask. However, once I select the alpha matte option I do not get the mask with in the path I have made-in fact not at all.
    can someone lend a hand I am just all out of patience. Thanks in advance
    John Cuevas replied 12 years, 2 months ago 2 Members · 2 Replies
  • John Cuevas
    July 12, 2014 at 11:26 am
    Try watching this basic tutorial on Keying & Transparency or this one, Motion Paths Part 3 – Masks & Paths. The answer is probably in one of those videos.
    And being new to AE, you should check out, Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Bur Ci
    July 12, 2014 at 6:50 pm
    John,
    hey thanks for the tips! I will definitely take a look at these tutorials. Thanks for the reply!!!
