Activity Forums Apple Motion masking problem with text modifier applied
  • masking problem with text modifier applied
    Posted by Joel Slabaugh on September 9, 2006 at 12:16 am
    I’m having a problem using text as a mask with text behaviors applied. I’m trying to mask a texture layer with a text layer that has a tracking behavior applied and for some reason the behavior doesn’t translate to the masked layer when the text layer is turned off. When the text layer is turned on the masked layer shows the tracking behavior. As soon as the text layer is turned off to reveal only the masked portion of the texture layer the tracking behavior disappears. Any explaination or work around would be much appreciated. Thanks in advance!
    Joel Slabaugh replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
