Activity › Forums › VEGAS Pro › Masking problem
  • Masking problem
    Posted by Kurtis Leitner on November 10, 2009 at 4:00 am
    When i take an object that i mask and put it on another background it kind of mixes in with the background. how do i make it so the masked object becomes clear?
    Joe Mantaratz replied 16 years, 9 months ago 3 Members · 2 Replies
  • Theo Van laar
    November 11, 2009 at 12:24 pm
    Did you create the mask in the EVENT PAN/CROP window? In that case could it be that you have set the value for FEATHER at something else then zero?
    Theo
  • Joe Mantaratz
    December 11, 2009 at 1:36 pm
    Make sure that you have the opacity set to 100% in the masking properties and also if you are looking for sharp edges then do not use any feathering as it will show through the edges. Other than that it should not show through at all. Let me know is this helps.
