Activity › Forums › Adobe After Effects › Masking on a layer with corner pin data
Posted by Ryan Paterson on November 5, 2011 at 10:25 pmhello, I’ve corner pinned a layer in Mocha and brought it into AE which works beuatifully. Only problem is I need to mask a the shape so that its not a perfect rectangle. When I apply a mask there is crazy distortion on it, is there an expression or script or something that can sort this out?
Ryan Paterson replied 14 years, 11 months ago 4 Members · 8 Replies -
Steve Blacker
November 5, 2011 at 10:36 pmHaving you tried precomping the layer before applying the mask?
It’s only work if you’d rather be doing something else…
Ryan Paterson
November 5, 2011 at 10:37 pmNo can do- i need the static mask to track along with the footage
Steve Blacker
November 5, 2011 at 11:16 pmI guess I don’t fully understand what it is you’re trying to achieve.
Ryan Paterson
November 5, 2011 at 11:18 pmBasically the corner pin data is tracking a perfect rectangle, im comping it onto a photograph with a little crease at the top, making the shape a litte bent at the top. I just want to be able to deform the rectangle slightly in the middle but still have the corners track as is.
Does that make sense?
Steve Blacker
November 6, 2011 at 12:15 amIf I were tracking a rectangle in some footage so I could apply the corner pin data to a photo, I would just prepare the photo (photoshop, whatever) so that it was already creased before applying the tracking data, using transparency where necessary.
But perhaps I still don’t get it. It’s late, and I’ve had a couple of beers… 😉
Ben G unguren
November 6, 2011 at 3:50 amUse Mocha for the masking as well as the corner pin! Mocha is designed to act this way. You motion track to get the right movement (via corner pin, for instance) but then you can use that tracking data to create an accurate rotoscope of the area where the properly moving footage is placed.
Two exports from Mocha: one with the corner pin, one with the mask. Obviously you’ll have to do some extra work in Mocha to make the mask, but it’s soooooo much easier in Mocha than in AE.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Roland R. kahlenberg
November 6, 2011 at 4:16 amGood points Ben. I just want to add that for non-rectangular inserts, Mocha’s Align to Surface feature is ideal.
HTH
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Ryan Paterson
November 6, 2011 at 8:37 amYa I was thinking something along those lines might be best, it’s about time I learned some more Mocha anyway. Thanks guys
