Masking off moving text with a feathered transparent mask
Hi there,
Have had a good look & can’t find the answer to this one – so here goes:
I’m going to animate some titles going over footage. Each titles slide needs to exit from the side but I want them to disappear through a feathered mask within the frame rather than just off the edge – kind of like this:
https://www.youtube.com/watch?v=Vsm9g316h6Y
Can’t quite work out how to do this – if I put a mask over the text it doesn’t stay put, and I can’t use a coloured vignette as i dont want to disturb the footage below.
Any help much appreciated.
Cheers,
ChrisSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
