Activity Forums Adobe Illustrator Masking object inside outline type
  • Masking object inside outline type
    Posted by Joe Bodego on July 24, 2016 at 10:05 am
    Hello, i have a series of lines that i would like to mask inside type that was converted to outline. How is this done, i tried but only one character of the type would mask. When i group all i get is a white background. Help!!
    Joe Bodego replied 10 years, 1 month ago 2 Members · 2 Replies
  • Vincent Rosati
    July 25, 2016 at 12:23 am
    Select all of the expanded text and Object / Compond Path / Make, then it will work as expected, as a single clipping mask.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Joe Bodego
    July 25, 2016 at 7:31 am
    Thank you so much, that worked out, a thousand thanks
