Activity Forums Adobe After Effects Masking multiple Particular solid layer
  • Masking multiple Particular solid layer
    Posted by Duca Simone luchini on August 27, 2014 at 8:53 am
    Hallo everybody,
    I meet a problem using a multiple 3d layer composited on a multiple fog banks particular (sandwich tech).
    Having two 3d layers I must use a multiple particular layers, tree exactly, to use them between the two different 3d layer. It works pretty good.
    But now I need to mask the tree particular fog bank to cut out some particles to match perspective scene orientation (see red mask).
    I didn’t find any solution about it…
    First, mask doesn’t work on a particular solid layer. Second, If I pre-compose the particular solid layer, it looses perspective set up (please, see attachments) with every set up…
    In this case I have tree particular solid, as well…
    So, may you suggest a solution to mask fog (as shown with red lines mask in picture 2)?
    Many thanks for a reply!
    Duca Simone luchini replied 12 years ago 50,979 Members · 1 Reply
