Activity Forums Adobe After Effects MAsking layers
  • Mike Clasby
    December 2, 2006 at 5:34 pm
    If you take the pen Tool and make a mask that is just inside the hill, and then another mask just inside the tower or pole, you can use Effect>Render>Fill (Check the “All Masks” box, and for Color, sample the Green background color, then you should be OK. The masks need to be closed masks (not open) snd accurate and just inside the lines, but you can fine tune it with Mask Expansion (twirl the Mask down). There might be an easier way, but this should work.
  • Ondrej Mencl
    December 2, 2006 at 10:11 pm
    Thanx fr the replay, but im not sure if this is what im looking for.
    … the problem is if i can use somehow two different layers to mask one layer without using precompositing
  • Tyler Paul
    December 3, 2006 at 6:08 pm
    You can use the set matte effect. One for each layer you’d like to use as a matte.
  • Ondrej Mencl
    December 6, 2006 at 8:58 am
    Bu the problem is if the layer im taking mask from is animated…the mask (set mate effect) is not moving
  • Tyler Paul
    December 7, 2006 at 3:57 pm
    Precomp the layers you’d like to use as a matte
    “Life Should Come With Backround Music”
    -Brown Sugar Studios-
    Tyler Paul’s Toonificator V3.0Example Clip
