Activity Forums Adobe After Effects Masking layer’s size change problem.
  • Masking layer’s size change problem.
    Posted by Eran Solomon on January 31, 2010 at 9:50 pm
    Hey everybody,
    so I used a layer with a mask on it to mask out my head from a video in a layer beneath it (Alpha Inverted)
    anyway, when i zoomed out i noticed the mistake i made and that the mask’s layer is smaller than the comp.
    the problem is , is when i press Comp Size on that layer properties , it resizes the mask aswell (doesnt fit anymore.)
    Is there anyway to solve this? make the layer bigger without making the mask itself grow ?
    Thanks in advance!
    Sachin Sundareshan replied 15 years, 6 months ago 3 Members · 2 Replies
  • Joey Foreman
    January 31, 2010 at 10:02 pm
    You could just Cut the mask, resize the layer, and Paste it back.
    If you’ve keyframed the mask, select all the keyframes, Cut those, resize the layer, and Paste em back.
  • Sachin Sundareshan
    March 21, 2011 at 8:17 am
    the only keyframe that is activated while shaping the mask is the mask shape, and this solution doesnt really seem to work
    Sachin Pillai
    Editor/D.A/Photoshop & After FX designer
    Freelancer
