Activity Forums Adobe After Effects Masking issues
  • Masking issues
    Posted by Oliver Abbott on January 9, 2020 at 12:11 pm
    Hi guys! I’m having some issues with a mask on a video layer in AE. As you can see in the image half of the image clips off at the same point each time within the comp. It does it for a few milli seconds and the rest of the clip is fine. I’ve messed around with the mas, turned all the effects on and off, and double checked all of the 3D positions with no luck. Any help with this would be greatly appreciated. Thanks
    Oliver Abbott replied 6 years, 7 months ago 2 Members · 2 Replies
  • Cassius Marques
    January 9, 2020 at 1:34 pm
    It really seems like a 3d intersection problem or memory cache.
    If you create an adjustment layer right under the car layer (to break the 3d stack order), does it solve the problem?
    Cassius Marques
    http://www.zapfilmes.com
  • Oliver Abbott
    January 9, 2020 at 1:54 pm
    Yeah, It really does seem like a 3d stack issue. But when I put the layer on its own the issue still arises. I have tried the adjustment layer with no success.
