Activity Forums Adobe After Effects Masking in 3D space
  • Masking in 3D space
    Posted by Aaron Stella on February 9, 2009 at 4:22 pm
    Is there a way to add a 3D mask? I have a cube made up of 6 solids, and I want to do a camera move on it, but also mask part of it out. This is part of a 3D Graph I am trying to create, and I want the bar (cube) to move up along the y axis, but I can’t figure out how to do that with out seeing it below the “floor”. Here’s a picture:
    Does this make sense?
    Aaron Stella replied 17 years, 7 months ago 3 Members · 4 Replies
  • Andrew Vanwickler
    February 9, 2009 at 5:18 pm
    It sounds like you just need to move your anchor point to the bottom of the cube.
    Andrew VanWickler
    vanwyklr@3dvw.com
    https://www.3dvw.com
  • Darby Edelen
    February 9, 2009 at 6:47 pm
    If you pre-compose your cube and place the bottom of it at the center of the pre-comp then you should be able to collapse transformations on that comp in your main composition and scale the cube on the Y-axis to make it grow.
    Darby Edelen
  • Aaron Stella
    February 9, 2009 at 7:53 pm
    I have tried that, but it only works if I don’t move the comp camera. The track matte is only cutting a 2D hole, so it looks weird if I do a camera move.
    Here is a copy of my .mov file. I tried moving the anchor point, but it didn’t help with the masking. Right now it is just a positional move up on the y-axis to make the bars grow. They are a 3D pre-comp.
    I would like to not have to keyframe scale if possible, as all of my other calculations are done based on y position.
  • Aaron Stella
    February 9, 2009 at 9:20 pm
    Thanks for your reply. I know keyframing the y-scale would work, but I want to remain flexible. It would work now, because it’s just a solid color for the 3D bar, but in case my clients want to add graphics or textures to the bars – I don’t want them to be stretched.
    Do you have any other ideas?
