Masking glass
I am shooting some high key glass images, and I am looking for optimal solution for masking them from the white-gray background. To make it easier, here is one of the images:
https://dl.dropboxusercontent.com/u/17422374/photos/test.jpgSo far the best method I found is to create path by using Pen tool and cut out all the background with the reflection as well. However it is very time consuming, and so I am looking for any tim that can speed it up.
I tried to play with the layer blending, find edges+invert but no result was satisfying (may be it can work on small image, but the original image has hight over 5000 mpx, and should last like that). Each time I lost some edges.
I would be glad for any idea that can speed up the masking (ideally something that would take couple of minutes 😉 ).
Thank you for any idea.
Regards
Jiri
