Activity Forums Adobe After Effects masking for lower third
  • masking for lower third
    Posted by Steve Morris on January 14, 2006 at 3:53 am
    I am having trouble creating a lower third which has an oval window off to the left side. I want to put a chroma keyed video of a person’s head rotating around, inside of the oval. I want the video to be behind the lower part of the oval, but I want the persons head to stick out above and infront of the topside of the oval. I hope this makes sense. If I had a place to post the video, it would be obvious what I am talking about. This would be easy to do with a still photo in Photoshop, but is much harder in motion.
    Steve Morris replied 20 years, 7 months ago 2 Members · 3 Replies
  • Jim Kanter
    January 14, 2006 at 4:41 am
    If I understand you correctly, you would sandwich the rotating head video between the full oval below it and a duplicate on the track above the head video. Be sure to mask the one above to reveal it only in the lower section.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Steve Morris
    January 14, 2006 at 5:11 am
    That makes sense. I don’t know why I was so confused on the isssue.
  • Steve Morris
    January 14, 2006 at 6:33 am
    For some reason I could not get the mask to work. I will need to study that more. I did work around it by going back to Photoshop, and earasing the top part of the oval, and importing that as the new top layer.
