Activity Forums Adobe After Effects Masking an Effect
  • Masking an Effect
    Posted by Evan Thompson on August 3, 2013 at 12:48 pm
    Hello,
    Question:
    How do I use a mask to mask the effect on a layer and not the layer itself? For example, I want to have a blur effect pass over a text layer, but I don’t want it effecting the entire layer all at the same time.
    Is this done by using expression controls? If so, how?
    -Evan
    Evan Thompson replied 13 years, 1 month ago 2 Members · 5 Replies
  • Todd Kopriva
    August 3, 2013 at 3:26 pm
    There are many ways. One is to put a mask on an adjustment layer and also apply the effect to the adjustment layer.
    These two videos show a couple of approaches:
    https://tv.adobe.com/watch/learn-by-video/adobe-after-effects-cs5-motion-tracking-and-rotoscoping/
    https://www.peachpit.com/podcasts/episode.aspx?e=eb0dc392-6e0c-4028-817d-cec647ffcc29
    After Effects team blog
  • Evan Thompson
    August 3, 2013 at 4:53 pm
    An adjustment layer! I don’t know why I didn’t think of that. I guess I was thinking on a different track.
    That should do the trick.
    Thank you!
    -Evan
  • Evan Thompson
    August 4, 2013 at 12:01 am
    And another quick question to go with that.
    What is the proper way to have the adjustment layer effect only select layers instead of everything below it? I know I can create a different sequence for just the layers I want effected, but is there a better way to do that?
    -Evan
  • Todd Kopriva
    August 4, 2013 at 12:30 am
    That’s not possible. That’s not how adjustment layers work. An adjustment layer applies to the composite of the layers beneath it.
    If you want to apply an effect to a specified set of layers, you have many options. Here are three:
    – Precompose the layers and apply the effect to the precomposition layer.
    – Precompose the layers and add an adjustment layer within the nested composition.
    – Apply the effect to each of the layers individually.
  • Evan Thompson
    August 4, 2013 at 1:02 am
    Alright, I can work with that. That’s as far as I knew about adjustment layers. I thought that maybe they could be applied to specific layers like in Photoshop.
    Thank you for your help and information. I appreciate it.
    -Evan
