Activity › Forums › Adobe After Effects › Masking an effect
  • Masking an effect
    Posted by Lewis Costin on August 5, 2012 at 8:47 am
    Hi. I am trying to limit Keylight to a section of my footage (my greenscreen) and I can’t find a way to use a simple mask to do this.
    Is there a way of using a mask to apply Keylight to only my masked area?
    Thanks.
    Erik Waluska replied 14 years, 1 month ago 3 Members · 2 Replies
  • Chris Brett
    August 5, 2012 at 1:55 pm
    Hi Lewis —
    — fairly new to this app myself ( so this might not work ) but have you tried opening an adjustment layer and applying mask and keylight to that …
    if that does not do the trick I think I would try pre-comping the job so far / making a copy / and applying keylight and mask to top copy ..
    — will be interesting to see what the others make of it
    —– all the best — chris brett —
  • Erik Waluska
    August 6, 2012 at 12:33 am
    “I think I would try pre-comping the job so far / making a copy / and applying keylight and mask to top copy ..”
    Yep, that’s what I would do.
