Activity Forums Apple Motion Masking a filter in Motion 2
  • Masking a filter in Motion 2
    Posted by Warren Gentry on December 16, 2005 at 8:59 am
    I’ve been trying to figure out if it is posssible to mask a filter applied to a clip in Motion 2 or in FCP, so as it only effects a selected portion of the frame. For instance, say I just want to darken or blur a specific area. Thanks for any advice.
    Arnie Schlissel replied 20 years, 9 months ago 3 Members · 2 Replies
  • Jim Kanter
    December 16, 2005 at 2:15 pm
    1. Duplicate the object to be filtered. Apply any animations/behaviors before duplicating it.
    2. Select the upper instance of the object, apply the filter and mask to it.
    The trick is to make sure the 2 instances of the object are synchronized and that the upper instance has the masked filtered area.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Arnie Schlissel
    December 16, 2005 at 8:34 pm
    [Jim Kanter] “The trick is to make sure the 2 instances of the object are synchronized and that the upper instance has the masked filtered area.”
    If you’re going to be applying any complicated moves on the layer, you might want to nest the original & masked layers together, then apply the motions to the nested layer. That way, when you make changes to the move, you only have to apply them to one object.
    Arnie
    https://www.arniepix.com
