Activity Forums Zaxwerks Masking 3D Invigorator
  • Masking 3D Invigorator
    Posted by Robert Kazden on September 10, 2005 at 8:22 pm
    This may be a dumb question…
    After creating text inside the 3D invigorator, you can no longer mask that layer. Once you lay down a mask, everything is still visible. I thought that once i precomposed it, i’d be able to mask it, but that didn’t work either. Is there a way to mask 3D Invigorator text?
    John Dickinson replied 21 years ago 2 Members · 1 Reply
  • John Dickinson
    September 11, 2005 at 8:32 pm
    Forgive me if this is obvious. When you precomposed did you choose the “Move All Attributes” option. By default when you precompose a single layer, the “Leave All Attributes” option is selected and this will leave the 3D Invigorator effect inside the main comp (not move it to the precomp).
    best,
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
