Activity Forums VEGAS Pro Masked text
  • Masked text
    Posted by Roger Bansemer on October 10, 2012 at 12:45 pm
    In this Vimeo piece at:
    https://vimeo.com/50892862
    some text disappears behind a persons head.
    How is that done?
    It’s at time frame 01:15 on the vimeo piece.
    Very interesting video by the way.
    I’ve always wondered how they do the graphics in football games that lay on the field and are masked by the players but I’d settle for knowing how the text is done on the Vimeo piece.
    Roger
    Roger Bansemer
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Roger Bansemer replied 13 years, 10 months ago 4 Members · 4 Replies
  • Steve Rhoden
    October 10, 2012 at 2:49 pm
    That bit 01:15 on Vimeo can be done easily with proper masking
    and a little patience.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Andrew Lenczycki
    October 10, 2012 at 3:52 pm
    I like seeing what people are trying to do on this forum because it gives me the impetus to try and figure out how I would do it. I layed down a video event on Track 3. On Track 1, I put Generated Media, Sony Text, and set the compositing mode to Multiply Mask. I duplicated the Generated Media, Sony Text from Track 1 to Track 2, and added the Sony Mask Generator FX to event in Track 2, setting the Mask to Alpha mode.
    I then went back to Track 1 media, selected Pan/Crop and turned on the Mask checkbox. I then created a mask, turning the Path: Mode from Positive to Negative. This has the effect that the area that I have masked is not visible in the video and gives the illusion that the text is “hidden” behind the video object (me). Using the masking tool, I had to change the mask of the text on each frame (keyframing) to account for my movement in the video. I did this quickly, so if you freeze a frame, you can see that the mask was not perfect, but when watching in normal play, the illusion is made. I’ve attached the short 3 second video test file I created.
    Masked Text
    Andrew Lenczycki
  • Jeff Schroeder
    October 10, 2012 at 4:24 pm
    Nice work Andrew!
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Roger Bansemer
    October 10, 2012 at 10:04 pm
    Thanks for that tutorial. I’ll have to try it step by step as I’m not that familiar with what “multiply mask” actually does.
    Thanks again.
    Roger
    Roger Bansemer
