Activity Forums Adobe After Effects Masked Layers Appear in Render
  • Masked Layers Appear in Render
    Posted by Mike Simmons on July 16, 2014 at 10:29 pm
    Ok, I’ve been looking for a solution for this, and it seems like people have had this problem before when OpenGl was the new thing, but that’s all changed with the new versions right? I’m using CC.
    I have a project where I’ve added some muzzle flashes, and I’ve duplicated the source layer and put them into add mode to replicate the brightness that would come with the flare. Then I masked out the objects that are in front of the flash (set masks to subtract) to they wouldn’t be affected. It looks great in my sequence, but when I render, the masks are gone and it looks like crap.
    Here are the images to show you:
    Here’s the good one
    And here’s the crap I end up with when I render
    I precomped the layers, so that’s not the problem. I tried all kinds of export settings (ProRes 422 HQ, Animation RGB+Alpha, lossless/best)
    Any clues?
    Michael Szalapski replied 12 years, 1 month ago 2 Members · 3 Replies
  • Mike Simmons
    July 16, 2014 at 11:33 pm
    It’s RED footage (.r3d)
  • Mike Simmons
    July 16, 2014 at 11:59 pm
    Here are some more images to show what’s going on.
    This is the original footage after I’ve used Primatte to key out the background.
    I duplicated the layer and set the blend mode to Add in order to brighten it up. You can see how the foreground object looks bright, and you can see the edges of the key. (you can also see my mask outline, but it’s set to None.)
    I created the mask and set it to subtract, and feathered the edges. Now it looks great. The foreground object is dark as it should be, and the key edges are gone.
    But when I render, it looks like the middle image – like my subtraction mask is gone.
  • Michael Szalapski
    July 17, 2014 at 1:10 pm
    It could be a cache issue. Try clearing all your caches.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
