Activity › Forums › Adobe After Effects › masked layer not appearing
  • masked layer not appearing
    Posted by Paul Norris on April 23, 2019 at 9:40 pm
    Hi. I have an after effects project that is extremely simple. I have a normal video with no effects and a video that is masked, with also no effects. however, when I play the composition or render the composition, the masked layer does not appear. i have never had this problem, I have scourged my project severely and there is absolutely no reason why it wouldn’t work. I am very, very annoyed and frustrated.
    Cassius Marques replied 7 years, 5 months ago 4 Members · 3 Replies
  • Kalleheikki Kannisto
    April 24, 2019 at 3:51 pm
    Make sure you are exporting the right comp. If you have a comp selected in the project panel you may accidentally export that instead of what you see in the comp window.
    Senior Graphic Designer
  • Walter Soyka
    April 24, 2019 at 4:03 pm
    Can you share some screenshots showing the problem and your complete Ae UI?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Cassius Marques
    April 24, 2019 at 5:41 pm
    The most common reason is that the layer is set to be a guide layer.
    Cassius Marques
    http://www.zapfilmes.com
