Activity Forums Adobe After Effects Masked area of layer casting shadow?
  • Masked area of layer casting shadow?
    Posted by Dan North on September 29, 2019 at 5:48 pm
    Hello there.
    I have an object I have animated and want to “hide” it at certain areas of the screen. (has to look like it’s going into a tunnel)
    I have made a solid above my object layer and made a mask where my “hidden” area is.
    I have set my object layer to A. Inv and my object disappear perfectly behind the mask.
    However the light that is lighting up the object is casting shadows of the “hidden” area” too..how can I make the light not affect the mask either? (mask is set to add)
    Any direction would be much appreciated.
    Best, Dan
    Graham Quince replied 6 years, 11 months ago 2 Members · 1 Reply
  • Graham Quince
    October 6, 2019 at 4:46 pm
    I take it the tunnel can’t be set to cast a shadow too? And you can’t fake the shadow using a copy of the object, tinted black and angled?
    In which case, I’d be tempted to create a second, copied layer for where the shadows going to fall on. And then mask this layer to match those parts where you don’t want your shadow to fall. Then set this masked layer to not accept shadows in the solid settings.
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
