Activity Forums Adobe After Effects Expressions Mask Vertex Expression
  • Mask Vertex Expression
    Posted by Martins Roc on November 28, 2016 at 11:30 am
    I need to connect 4 mask vertices to separate null objects. “Connect Point to Mask Vertex” script by CRgreen doesn’t seem to be working in the current version of After Effects and I’m trying to use nab’s MaskVertexExpression instead.
    However, so far I’ve only been able to connect 1 vertex to to 1 null, but not the 4 vertices to separate nulls. My mask has 8 vertices and I just need to either connect the bottom 4 to nulls or to keep them at the initial position. The mask is animated.
    Anyone has any idea how to write an expression that would achieve this?
    Best regards
    Martins Roc replied 9 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
