Activity Forums Adobe After Effects Mask Tool won’t go away
  • Mask Tool won’t go away
    Posted by Steven Berkani on July 20, 2018 at 12:31 pm
    When I started working on my project, I had no issue. I then went from using my mask tool to the move tool. It won’t work. It seems that it’s stuck on the mask tool, even though the move tool is selected. When I drag out my mask, my move tool becomes active. I then try and delete the mask. It deletes the layer instead. I’m not what to do from here, but any help would be much appreciated, thanks.
    Steven Berkani replied 8 years, 1 month ago 2 Members · 3 Replies
  • David Byrne
    July 20, 2018 at 12:38 pm
    I’m not sure exactly if the issue you are having is to do with mouse / pen / touchpad interface, a lag with after effects or user error – however –
    Select your layer (Number of layer on Keyboard numpad or just with mouse) and press M to reveal any masks, you can delete, select and unselect them within the timeline rather than the composition window. You can also do this by selecting your mask in the composition window too. Pressing M reveals the Mask. Pressing MM reveals its properties.
    Press F2 to unselect everything if you need to access the Move tool. Press V on Keyboard to access move tool and G to access pen tool. Pressing Q cycles through the defined Mask Shapes (Rectangle, Circle, Star etc).
    Definitely get used to using Keyboard shortcuts, they will save you hours of work on every project.
    Cheers!
    David Byrne
    Animo Motion Graphics
    Freelancer, UK
  • Steven Berkani
    July 20, 2018 at 4:00 pm
    I’m using a touchpad. I’m working with a pre-comp layer.
  • Steven Berkani
    July 20, 2018 at 4:11 pm
    When I attempt to undo my mask selection, it will not undo. However, when I open up my pre-comp layer, I’m able to use the move tool again.
