Activity Forums Adobe After Effects Mask tool always turned on
  • Mask tool always turned on
    Posted by Philippe Gosselin on March 20, 2013 at 11:36 pm
    Hi all,
    Take a look at the screenshot. You can clearly see that the pointer tool is selected but the cursor stays in mask mode. Even pressing “V” doesn’t change anything.
    The cursor doesn’t show in the screenshot but it looks like a “+” sign. The only thing I can do , whether a layer is selected or not, is to create this white rectangle box/mask which can’t be removed afterwards. I’ve tried restarting AE, and create a brand new project, all to no vail.
    Thanks for the input
    William Scholik replied 13 years, 5 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    March 21, 2013 at 1:02 am
    Try a delete Prefs routine – CTRL+ALT+SHIFT while AE starts up (leave the keys depressed until a dialog window prompts you if you’d like to delete the Prefs file.
    BTW, Windows has a built-in, single-image screen recorder that records the cursor. Type “psr” in the Search Progs and Files text entry area and launch psr.exe
    You screen actions will be captured into a Zip file containing an HTML file with embedded screen captures images. You can then use the regular Print Screen key on the embedded images.
    More info here – https://windows.microsoft.com/en-us/windows7/how-do-i-use-problem-steps-recorder
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Philippe Gosselin
    March 21, 2013 at 2:16 am
    I was able to delete the Prefs but once I open the project the problem remains.
    I’ve actually started again from scratch, thank god I just started the to work on it.
    Which begs the question, is there anything else I could do if that issue was to happen again?
    Phil
    ps, thanks for the Win7 tip
    March 21, 2013 at 2:41 am
    It seems like your currently selected tool is stuck in pen mode. For a quick fix, deselect the Mask/Shape Path Visibility button at the bottom of the Comp Panel.
    For a long-term fix which may or may not work – try selecting another tool to see if this refreshes the ‘sticky’ nature of the Pen Tool.
    HTH
    RoRK
  • William Scholik
    March 21, 2013 at 3:31 pm
    It looks like you have the “region of interest” button toggled. You should be able to correct your problem by hitting it again. It is the button next to the resolution selector in the compviewer.
    “We cannot solve our problems with the same thinking we used when we created them.”
    ― Albert Einstein
