Activity › Forums › Adobe After Effects › Mask Shapes…
Mask Shapes…
Posted by Ron Dejoseph on March 29, 2007 at 5:20 pmdefaults are rectangle and elipse…
how do you make a perfect square or perfect circle mask? in AE?
Darby Edelen replied 19 years, 5 months ago 4 Members · 4 Replies -
Todd Gillespie
March 29, 2007 at 6:09 pmHold shift when you drag.
Cheers,
Todd at UCSB
Television Production -
Darby Edelen
March 29, 2007 at 11:01 pm[Dave LaRonde] “and if you have any thought of animating the rotation of these perfect shapes in AE, work in a square-pixel comp, rather than a non-square-pixel comp. The pixel aspect ratio in this situation needs to be 1.”
I don’t think this is true, unless you’re proposing rotating something I’m not aware of. Just to make sure I did a test in an AE7 0.9 Comp and rotated the mask and the layer, in both cases it maintains it’s perfect circle ratio.
Mike Clasby
March 30, 2007 at 2:23 amMethinks it only wobbles if you rotate a square pixel circle (like from PS or a square pixel comp) in a .9 comp, or visy-versy.
I was lucky enough to be at the AE NYC user group meeting and Shape Layers are going to be revolutionary for After Effects, very cool, like they imported much of Illustrator into AE.
Darby Edelen
March 30, 2007 at 6:55 am[yikesmikes] “Methinks it only wobbles if you rotate a square pixel circle (like from PS or a square pixel comp) in a .9 comp, or visy-versy.”
Yeah, that was kind of what I was thinking he might be referring to. But it doesn’t apply when you’re working with in AE or PS as long as you stick with the aspect ratio that you’ll be outputting to throughout the project. Everything should turn out gravy.
