Activity Forums Adobe After Effects Mask problem – overlapping spline results in hole
  • Mask problem – overlapping spline results in hole
    Posted by Aled Rhys jones on July 23, 2010 at 11:05 am
    How do I get a mask path NOT to produce a hole (negative value) when the Mask Path crosses itself?
    …see image here:
    David Johnson replied 16 years ago 2 Members · 1 Reply
  • David Johnson
    July 23, 2010 at 12:18 pm
    You would normally use the pen toll with the “-” symbol to delete the vertices that create the hole and you’re done (the equivalent of having originally drawn the mask without the hole). However, since you say that you want that mask to remain as-is without specifying what you’re trying to accomplish by doing that, the only way I can think of to do that is to duplicate that mask, delete all the vertices other than those that create the hole (the outer ones), then change the duplicate to the opposite mode (subtract or intersect).
    Hope this helps.
