  • Posted by Rob Schof on May 27, 2009 at 5:22 pm
    hello,
    i have about 200 layers with masks and i want to link the expansion and feather to an expression slider. i have no problem with that, but when i make the expressions a preset and then apply them it creates a new mask on each layer instead of applying it to the existing mask. same thing happens when i copy and paste expression only. is there a way to copy the expressions to pre-existing masks?
    thanks!
    Dan Ebberts
    replied 17 years, 4 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    May 27, 2009 at 5:58 pm
    It looks like the mask needs to be selected. Alternatively, you should be able to do it with a script, depending on exactly what you’re trying to do.
    Dan
