Activity › Forums › Adobe After Effects › mask points in 3dspace
Posted by Corillo181 on June 5, 2007 at 6:37 amis it possible to animate a mask point in 3 space? i know i can move it up and down front back .. but is it possible to do it in 3d space?
Mike Clasby replied 19 years, 3 months ago 4 Members · 3 Replies -
Mark
June 5, 2007 at 9:45 amI believe that the mask is a 2d property. What are you trying to achieve ???
Steve Roberts
June 5, 2007 at 11:44 amYep, because a layer is a flat 2D plane, and a mask on a layer has to reside on that plane.
I echo Mark’s question: what are you trying to achieve? Maybe we can find another way.
Mike Clasby
June 5, 2007 at 4:22 pmThe only case I can think of that works easily is if you had a sqaure mask the size of the layer (select layer, then double click the Rectangular Mask Tool), make it a 3D layer, then as you animate the layer in 3D space, the layer corners will be the same as the mask vertices, giving you a lot of control ovwer their placement.
Otherwise, not so easy.
Echo… What are you tring to do… do… do… ?
