Activity › Forums › Adobe After Effects › Mask Path
  • Juhani Hakanen
    February 26, 2009 at 2:39 pm
    I forgot to add that I use After Effects CS3.
  • Todd Kopriva
    February 26, 2009 at 3:32 pm
    Dean’s tutorial was created before shape layers existed in After Effects, so the instructions are a bit different, now that the various tools for drawing paths can be used for either masks or shapes.
    Now, to draw a mask on a layer, you have to make sure that the layer is selected first.
    You can also copy and paste a shape path to a mask path. The easiest way to do this is to create a dummy mask (for example, by selecting the layer and just clicking once in it with the Pen tool), select the Path property of the shape layer, press Ctrl+C, select the Path property of the mask, and press Ctrl+V.
    There’s detailed information about creating shapes and masks and transferring paths from one to the other in the “Creating shapes and masks” section of After Effects Help.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
