Activity Forums Adobe After Effects Expressions Mask path and linear expression
  • Mask path and linear expression
    Posted by Riccardo Schito on November 12, 2019 at 4:52 pm
    Hi all!
    I’m trying to do a simple setup so that every time I move a layer, a mask path animates.
    I know that the problem (at least for my newbieness) about mask path is that there’s no changeable value like any other properties, so I tried to use index key to set a linear expression.
    It doesn’t work because the error says “Path object found where a number array or property is needed”.
    This is not urgent , I can skip this things by simply animating mask keyframes, but I don’t know how to do that, and that drives me crazy.
    If anybody can help me, well… Thank you in advice!
    var A = thisComp.layer("layer").transform.position[0];
    linear (A,0,100,key(1),key(2))
    Dan Ebberts replied 1 year, 6 months ago 4 Members · 4 Replies
  • Alex Printz
    November 12, 2019 at 5:48 pm
    try it like this:
    valueAtTime(linear(A,0,100,key(1).time,key(2).time))
    Alex Printz
    Mograph Designer
  • Riccardo Schito
    November 15, 2019 at 6:04 pm
    Mmh, no I’m sorry, it doesn’t work.
    I thought it was a issue with the inPoint of each layer, so I tried to add a var T= time – (thisComp.layer(“layer”).inPoint + inPoint) but then the expression becomes incorrect…
  • Florian Mondl
    January 27, 2025 at 2:18 pm
    Path interpolations can not be done like this. You need to place your keyframes at a fixed time interval (for example one second) and then apply the linear function to the mask path like this:
    var A = thisComp.layer(“layer”).transform.position[0];
    t = linear(A, 0, 100, 0, 1); valueAtTime(t+thisLayer.inPoint);
  • Dan Ebberts
    January 27, 2025 at 8:20 pm
    I think this is what you’re after:
    a = thisComp.layer("layer").transform.position[0];
    t = linear(a,0,100,key(1).time,key(2).time);
    valueAtTime(t)
