Activity › Forums › Adobe After Effects › Mask Opacity Issues
  • Mask Opacity Issues
    Posted by Andrew Furlong on March 29, 2008 at 7:48 pm
    Whenever I change the opacity of my subtract mask to 0%, the entire frame changes to 0%. Why is this happening? the frame transform setting is always at 100% opacity. I’m ripping my hair out.
    Andrew Furlong replied 18 years, 6 months ago 2 Members · 2 Replies
  • Darby Edelen
    March 30, 2008 at 7:10 am
    The ‘subtract’ mode for AE masks does not work in a way that really makes sense logically. If you want to make it work more intuitively try applying an add mask to your entire image first (you can double click the rectangular mask tool to do this) then apply your subtract mask and adjust its opacity.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Andrew Furlong
    March 30, 2008 at 7:35 pm
    Oh cool, thanks so much. What I ended up doing was just cut and paste the mask into a solid white shape layer and did a luma track matte, it produced the same result just with like 4 extra steps lol. I’ll try that add/subtract method though, thanks so much. I wonder why the subtract mode isn’t what it appears.
