mask opacity bug in AE 6.5
In searching for the source of a mysterious shift in layer dimensions, I found the culprit: mask opacity keyframes are causing the layer to distort slightly, right at the keyframe time but then returning to normal. Has this bug been noticed by anyone else? Is there a cure?
