Activity Forums Adobe After Effects Mask on a Solid with Advanced Lightsning
  • Mask on a Solid with Advanced Lightsning
    Posted by David Bark on May 23, 2010 at 7:53 pm
    I can’t seem to apply a mask on a solid layer with Advanced Lightning applied. I’d like to see the Lightning come out of the “clouds” rather than the top of the screen. I suppose I could move the origin point, but that would be a pretty harsh start. I’d like the lightning to emerge from behind a feathered mask.
    The background is an AE file that sits behind everything. I’ve got four solid layers with Adv. Lightning applied. Applying a mask to those layers doesn’t affect the lightning itself.
    I could create a feathered shape layer that mimics the AI files “Clouds”/”Ground” but I’m wondering if there’s a better way?
    David Bark
    Lightshine Productions
    Scott Novasic replied 16 years, 4 months ago 2 Members · 1 Reply
  • Scott Novasic
    May 24, 2010 at 6:42 am
    simply pre-comp the advanced lightning layer… then all your bezier masking tools should work fine for feathering….
    Scott
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
