Activity Forums Adobe After Effects mask madness – ready to kill
  • mask madness – ready to kill
    Posted by Antony Buonomo on August 8, 2005 at 8:19 pm
    Is there any crazy reason why a mask shouldn’t work properly on a comp that is 3d?
    I have a pre-comp within a main comp. Inside the pre-comp is a design that I want to reveal slowly. In the main comp I draw a mask on the pre-comp layer but it’s not masking where I draw, somehow a different part of the layer is being masked; a smaller version of the one I’m drawing, but
    There is a camera in the main comp, the pre-comp layer is set to 3d and so is the solid layer within the pre-comp. I’ve tried various combinations of turning 3d layers on and off and either the crazy mask appears or the vector shapes are blurry. However, the blurriness only disappears when I check the ‘continuous rasterization’ option.
    WHAT THE HELL IS GOING ON?
    A
    AE Pro 6.5/Mac G5 Dual
    Tom Hodgkinson replied 21 years, 1 month ago 3 Members · 3 Replies
  • Arthur Vibert
    August 8, 2005 at 8:39 pm
    Have you tried pre-rendering the precomp?
    Arthur VIbert
  • Antony Buonomo
    August 8, 2005 at 9:57 pm
    Thanks, but I need the flexibility at the moment and don’t want to pre-render. Any idea why this is happening? Is it a bug?
  • Tom Hodgkinson
    August 9, 2005 at 12:37 pm
    Have you tried applying the mask to the footage in the (2D)precomp rather than
    within the main (3D)comp.
    I have had similar problems with masks before which I have solved by applying them
    in 2D space.
    Hope that helps.
